Discuss Bath self drained overnight in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Long story short, filled new bath to silicone seal. Didn't touch pop up/click waste and noticed that 90% of the water has drained overnight.
Is this normal or should these wastes block the water indefinitely?
Yea they don’t seal 100% you can get better than others
It could have been going under the flange rather than down the centre of the waste past the plug. Did you use silicone between flange and bath? - some of the foam seals are poor (usually bin them).
But like you say probably not an issue in normal use, so as long as there’s no leak under the bath - just leave it.
Given it a couple weeks use and looks like all fine, no actual leak, obviously not making a perfect seal with click wastes but does the temporary job it's meant to do I guess
Reply to Bath self drained overnight in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello everyone. New to the forum and looking for assistance / advice. I live in a rented house with a not very co-operative landlord. I have just...
Hi, I have a few issues with my bath drainage and leaking. The first issue is that the near corner of the bath by the taps is sloped downwards...
Hello All, I have an issue and hoping someone could shed some light on the problem. We have been getting a smell coming up in the bathroom...
Firstly, I already have a fair idea of what I need to do to fix the problem (I hope plunging will fix it, I just need to buy one), I would just...
Hi, the water in my bathtub has been draining really slowly recently. I investigated it today and there was a large build up of gunk right under...
