Discuss Baxi 100 HE ignition problem in the Central Heating Forum area at PlumbersForums.net
As above however if your GSR engineer diagnosis requires replacement parts then have a look at Ignite Heat Spares for fully reconditioned parts at less than half new ones and in my experience with their Baxi parts is that the quality is better than new. Usually they send your part to you same day and you send the u/s one back, I have used them for Baxi parts for a number of years. Centralheatking
Reply to Baxi 100 HE ignition problem in the Central Heating Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
