Boeing
Hello
I have looked through many threads and I need some more advice.
Baxi megaflow 24 HE
Explosive ignition:
basically the the boiler will or will not fire up with a loud bang enough to rattle units
for a while it is fine but after a day it gets progressively worse , had engineer out and it all checked good , although he did find a little moisture in fan , boiler is 6 years old , he said HE a little worn from the starting problem but should be fine , he fired it up and it behaved ,24 ours later and bangs got worse and then one very loud one and boiler shut down showing ei33
i opened it up to check everything and reset ,it is now running again with normal ignition , but for how long , he suggested a new boiler or possible gas valve replacement . I would really appreciate some advice on this as to which road I should go down
brgds
james
Baxi megaflow 24 HE
Explosive ignition:
brgds
james
