Discuss Best / Most Cost Effective Pressfit (Copper) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Worcester
With all the solar work and other types of renewables that we do it's time to consider investing in a press-fit kit. :)
For those of you that don't know, in solar we can't generally use solder, so that usually means compression fittings with brass olives. However we know that we can get solar rated press-fit fittings.
We need 15,22,28,35 as a minimum, (and occassionally 42mm)
We're looking to speed up our work though and so are going to go down the press-fit / mapress / Xpress route. As we've not used them extensively before would like your guys feed back on which one to go for and why?
Cost of tool, cost of fittings, availability of fittings, compatibility of tools and fittings, who stocks what etc.
64 views and not a single reply :(
So I take no-one uses pressfit copper just your "anyone can be a plumber" push fit plastic instead :) or else it's "capillary solder for me boy, nothing else as good" :)
Lights touch paper and retires to safe distance :)
dont do solar but use mapress alot and easyily available however crimping tool is a nice cost
Our customers mostly seem to use DN16 pipe and fittings with solar.
Thanks Ray, our installations don't tend to be for 'typical' customers, our average domestic customer profile is 200m2 + property so installation is always more than a pair of DN16 pipes and fittings ! - almost always a thermal store and multiple other renewables sources:
Typical customers house :) - Solar PVT, Wood burning back burner heating stoves, GSHP and UFH reftrofit going in here:
We use yorkshire pressfit solar in work comes with a green rubber ring and is great stuff, quick and neat
I can't recommend Geberit enough.
I've regularly use anything from 15mm to 108mm and can't fault there fittings, pipe or equipment.
I can't comment on cost as this is handled through our buyer and all of our machines are hired through MEP. All of our fittings, stainless steel and carbon steel come's from Pipe Centre, Mapress don't produce copper pipe so just regular Yorkshire copper is used. As you are using 15-42mm you could get a battery crimper, the 110v versions are quite bulky and heavy.
As Michael Davis says for the solar pipework you need to swap the o-rings inside the fittings for the high temp ones, but this will all be explained once you've done the Geberit course!! :). We get a refresher course annually, it's quite good, they're always developing so there's always something new to learn.
The novopress battery powered tools are very good.
Just checked out your website worcester ! Nice! Would love to get experience in the same area.
i have only seen geberit used.
Give them a ring, sure they will come give you a demo
The best and most cost effective fitting for you would be one that the manufacturer guarantees for solar installation.
Most pressfit fittings, if you look at the manufacturers data, are only recommended for certain temperatures.
Solar Hot Water will have temperature up to and above at times of over 100 C and run at high temperatures for extended periods of time.
I would be looking at a product that is guaranteed, by the manufacturer, for temperatures that will be expected in solar installations.
Reply to Best / Most Cost Effective Pressfit (Copper) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello. I hope someone here has the expertise to help. I know exactly what situation it took awhile. On the loft on the 6th floor there is a...
Had a job booked in this morning, renew all rads in the property. Downstairs rads are in solid floor so customer said just change rads and alter...
  • Locked
**im reposting this because i needed to make some edits to the first thread i made and i cant because its been more than an hour since i first...
4K
T
  • Locked
i am trying to replicate a victorian brass and copper shower. i already have a brass mixer tap but i need a brass riser. does anyone know where i...
6K
lame plumber
L
