Discuss Best type of outdoor tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
badbob
I'm going to fit a outdoor tap, I bought the focus DIY one. It looks like when you drill a hole, the hosepipe comes out of the hole then attaches to the tap (and the hosepipe is visible)
I spotted another type, where the hosepipe fits to the back of the pipe bracket, so it's quite a bit neater, as you have no visible hosepipe.
But I'm wondering if there's a leak with the hidden version, it may not be noticed for a while and may damage the brick. And if the visible pipe model does leak no need to remove the tap.
Image.ashx
if you go to plumb centre they do a back plate for a hose union tap with a 15mm copper pipe straight out of the back of it, drill a hole through wall push pipe through wall and drill 3 holes to fix to wall. screw your tap into the plate that is on the wall and bobs your uncle
Try this type, you will get it from any good plumbers merchants.
http://www.NoLinkingToThis/sfd/i/cat/01/p44301_l.jpg
Pete
Reply to Best type of outdoor tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Around 4 years ago I installed a Swirl Magellan Bath Shower Mixer Tap onto a bath. This tap looks something similar to the following in terms of...
3K
A number of issues have been raised from a boiler replacement. Boiler not operating and with no pressure. Tile damage Sprawling pipe layout in...
5K
  • Locked
Hi I'm just a DIY'er popping over from the tiler forum. I've got problem trying to fit a basin mixer monoblock type tap. The tap is connected by...
16K
fuzzy
F
W
  • Locked
I noticed the other day a slight leak. Where the washing machine hose connects to the cold water pipe (washing machine valve) there is a gradual...
3K
dontknowitall
M
  • Locked
Hello people, I am 32 years old and I'm looking at changing my job, plumbing interests me. What is the best route into this industry? My...
1K
Mr Essex
M
