Discuss Best way to remove ancient hemp from a thread? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
No, use a wire brush on an angle grinder - drill. If its in your hand, a hacksaw blade run along the threads.
Best way of all is clean the threads out with a BSP die nut (or die head)
By now you probably realise i do a lot of iron pipework!
Buy yourself a 1/2" and 3/4" taper die nut. Invaluable for all sorts, clean off old hemp, repai something thats been cross threaded etc.
Reply to Best way to remove ancient hemp from a thread? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The inside brass threads in my Moen rough in two handle Roman tub valve (Moen | Bathroom & Kitchen Faucets, Shower Heads, Accessories & More -...
1K
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW...
Hi. Would be really grateful for some help with this. I am trying to replace the fill unit in my toilet and the only way I can see that this would...
1K
Morning everyone. We have a leak from one of cistern holding down bolts on our close coupled WC. This has occurred after a plumber replaced the...
3K
Hi, As some of you are aware, I am currently stuck in Italy running a shop that has nothing to do with plumbing :( Yesterday I thought I'd got...
3K
