Discuss Biasi Riva M90E.32S Problem, getting running hot water but no central heating??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
georgealley
Hi can someone please help
I have a biasi boiler come home from work on new years day and i no longer have central heating.
I have running hot water on demand but when i turn the thermostat on for the central heating it turns on for approx 10 seconds i hear the pump etc and then automatically switches off i have no ignition at all.
Can anyone help or provide any advice on where to start please
as mentioned hot water works fine everything switches on its just the central heating issue
Welcome to the forum mate. I think you will need an engineer out to take a look. Try posting here, [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
This plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
Reply to Biasi Riva M90E.32S Problem, getting running hot water but no central heating??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
