Discuss Bleeding tube for an oil burner in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
eagel
Hi we have got an Worcester Greenstar heat slave 12/18 boiler and had to recently bleed it. it was quite ***bersome and a tube with a valve, which one can turn off would make it easier. any body know where i can buy one and what it is called?
i saw on on u tube but he did not say where to buy it or what it is called.
thanks
Sorry friend but that doesnt make a whole lot of sense. What are you bleeding?
presSure testing kits cost 380 plus vat and they have a connector and tube to bleed the pump, or disconnedt the flexi hose and suck on the end, or call an engineer and after that dont let you tank run dry.
Reply to Bleeding tube for an oil burner in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
