Discuss Blocked oil feed pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
RUPERTC
10 M of copper 8mm oil feed pipeline from tank with only a 1m head.
Oil not reaching boiler.
Replaced filters.
Is there a way to rod such a small pipe?
get your suction pump on it or blast it out with a compressor (with other end tied into a rubble sack)
I assumed the fire valve etc is clear and not in the line
Replaced filters.
Think the boys use a compressor for this.
DO NOT PUT A FINGER OVER THE END OF THE PIPE WHILST DOING IT! !!!
Have you dipped the tank to make sure there is plenty of fuel?
Reply to Blocked oil feed pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
