Discuss Boiler ALPHA CD28C repressurize in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Orange
My boiler is losing pressure. I cannot not find the filling valve.
Can anyone help, please?
Many thanks!
Your missing two black levers (like washing machine valves) have you got a set of pliers ?
Hi Shaun,
I do. Which part of the boiler should I toucan, please?
Many thanks.
The flex pipe either end should be a brass tail sticking out (silver valves that the flex is attached to)
There's two flats on the brass tail, inline with the pipe open and shut is across like in your pic
Open the least accessible one first (already might be open hard to see)
Then open the other one slowly once you reach about 1-1.25 bar cold close the valves
All sorted ??
Don't forget to close one or both of them :D
I'll let you know once I have found the courage to do it. I'm terrible at such jobs :-(
Reply to Boiler ALPHA CD28C repressurize in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
