Discuss Boiler issue - cant increase pressures in the Central Heating Forum area at PlumbersForums.net
We have a potterton apollo boiler and it's showing a E1 fault due to a drop in pressure.
Normally I just pull down the green lever inside to increase the pressure but zilch is happening when I do this.
Any suggestions?
You have water through your hot taps ?
That green lever isn’t something I’m familiar wit, it looks a little like a pressure relief valve. It also looks like you may have an external filling loop connection setup as well?
Any suggestions?
The Baxi guy told me this replaced the filling loop, so I'm not sure. They changed it about 2 years ago.
There not that good they do stick / fail
Yes they do. Looks like they’re usable, precursor though- they may leak. Remove the caps, Attach the filling loop to both valves, and using a flat bladed screwdriver or a kitchen knife turn both valves and you shouldn’t be able to get boiler back up and running.
Thanks. We managed to get the left one off and it did leak but the right one just wouldn't budge with tools. Even my neighbour tried.
I wish I had known how feeble those green levers are as I would have told them not to change it. Its frustrating having to pay someone to come and fix it.
Reply to Boiler issue - cant increase pressures in the Central Heating Forum area at PlumbersForums.net
I have done pressure test for 2" high pressure pipe line by closing the pipe with rubber plugs at the ends. It was 3 bar and I kept it for 24...
