Discuss Boiler replacement flueing option advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
RDS
Hi all,
Been asked to quote for boiler replacement and went outside and saw this:
The customer wants an Alpha etec 20s, even with the plume kit its not gonna meet regs. Looking for suggestions without having to move boiler location - is it possible??. Thoughts much appreciated....
a33e1c7e673e2de4218d7dc5a3134d6e
Vaillant with an elbow and extension externally with sealed collars and the horizontal terminal on the end? (Make sure it is supported correctly) I wouldn’t do it like that and would tell them it needs moving elsewhere. But have seen it done like that and Vaillant say that it is ok as long as collars are sealed correctly.
Thanks for advice guys much appreciated, I thought as much too! Nightmare to move boiler with pipework under tiled and laminated floors and not much space to relocate elsewhere. Customer adamant about having an Alpha, though suspect they may keen for a Vaillant as suggested when extent of work realised! I wouldn't be keen on the Vaillant flue run either!
Just had a thought, but with 90 degree bend with horizontal extension and terminal it would need to clear rear wall of house I assume. That's a further 4/5 metres behind me from where I took the pic!
Reply to Boiler replacement flueing option advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
