Discuss Boilermate boiler pump replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumb_know
Hi Everyone,
Replaced boilermate boiler flow/return pump yesterday as old one was fried but just used a standard grundfos ups3 as seen people say standard pumps are ok to use for boiler & heating circuit of boilermate, customer says heating demand is constantly on now. I just wanted to check this would not have anything to do with the new pump as in the past i have always just fitted the manufacture replacement for the existing pumps, but do not see why this would affect the heating calling for heat anyway??
I personally think it would be a controller issue or boilermate PCB but just wanted some some more experienced heads opinion before i go back out. I put new pump valves on so wont be massive issue if i need to get the original pump and fit, but dont want to do this then it be a separate issue.
Appreciate your advice.
Many thanks
Which BoilerMate is it as there are a few different models? In my experience of these when a pump burns out it takes the pcb out with it, not always but because the pump is trying harder it increases the load through the pcb and melts the chip.
Reply to Boilermate boiler pump replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the...
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to...
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs...
