Discuss Boss Boiler Condensate Pump packed in in the USA area at PlumbersForums.net
So the boiler wasn't powering on because the condensate pump had packed in, well the pump had swicthed off and thus cut the power to the boiler. Once the pump was decanted of its water, the boiler tuned on.
So the pump needs replacing - should I replace with another Boss or are there better pumps on the market?
Pump house ones are decent depends how long you’ve had the boss one ?
In reality around 30 mins but you will be billed for an hour
If the hose needs replacing as well depends on route / access
Reply to Boss Boiler Condensate Pump packed in in the USA area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
PSxxxxxx
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
