Discuss Brand New To Forum Hoping For Help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone.
I hope this is the right section to post this, so here goes. If not, my apologies, newbie here.
I am removing a radiator in my 1995 wimpy house (Im sure that strikes terror into the heart of any experienced builder) for decorating purposes. Let's just say they never mist coated the dry walls so the paint is essentially wallpaper and its cracked badly.
Here are some pics prior to removal:
From what I can tell, this seems like a standard non thermostat fitting.
I've closed off both valves and cracked open the nuts both at ends, as seen in the above pics (also opened bleed valve), let the water drain out, so the radiator is now empty. So far so good.
I've had a friend help prise the pipes apart as they were a very tight fit (they seemed spring loaded into the radiator due to the close pipe fitting).
I was then thinking of changing the manky Stainless Steel valves? To fresh looking ones, since decorating the room but this is where the fun will really start, i.e. more serious pluming.
Here is a pic of the radiator connector ports? (not sure of nomenclature).
Now, I cannot seem to get the nuts off either end and I assume that's because there is an olive? Clamped to both ends stopping this.
This however shouldn't be an issue as I need to remove the whole piece from within the radiator, that being what a plumbers wrench? Is used for. I can see ptfe? tape coming out of both radiator ports, so I assume something has been screwed into both ends.
I'm going to go ahead and assume that I unwind those inserts out of the radiator as they will be replaced with the new valve kits I buy.
I then have to put some PTFE? tape around the new insert and some plumbers compound? So to make a good seal. Can you buy inserts with a better system, i.e with washers already included (although I doubt olive ones). Some seem to have black grommets/washers as well but they were on spacers not the standard valve kit I saw in the box? If so, part names, numbers, or URL's would be great.
Here are 2 pictures of the remaining pipes and the valves I will have to remove to put on new ones.
To remove these I will need to undo the nuts but before doing that I will need to turn off the water heating system and boiler.
I know that I can either close off the mains riser (under my sink), tie up the ballcock in the loft (haven't been up there in 10 years and don't want to, don't even have ladder to get up there), or locate what could be a valve in the airing cupboard, which brings me to the most bemusing part of all, my airing cupboard.
Check this out! (probably a separate thread in itself).
I have started labelling what I think is going on, although if anyone knows exactly, please tell me.
I think the water heating system is turned on or off by the red wheel valve? Located nearest the door. The big pipe at the back is the main cold into the cylinder and although the pump is upside down? That feeds the 2 port, 3 way switch? Into the coil. Why is the pump upside down? is this to do with the way the mains feeds into the roof?
I cant really figure out why the pipe I selected as the water heating pipe with red valve, is the water heating pipe, as I see no immediate connection but I also don't see any other need for a pipe to have a shut off valve. (The pen marking is mine)
Right so I will shut that off, and prepare to shut of the mains riser too if the system doesn't seem to drain. I also hear when draining the system that I should switch the metal box at the bottom of the pic into 'Manual' instead of auto and leave it on 'Manual' when filling. Why is that, out of curiosity?
But here is the next issue.
This is the drain pipe added to the radiator on the bottom floor.
Yeh weird right? And it leaks, so I want to get rid of that too!
I suppose without this thread getting too long on my part I should stop and ask
1) How do I remove the olive washer from the pipe going up into the valve once I remove the valve, so I don't have to cut the pipe to get it off?
I assume there will be one when I undo the nuts on the valves
2) Is that the heater pipe and valve in my airing cupboard and will closing that off help me drain the system? I assume it will, if it is indeed the correct valve.
3) Can you kindly give me any names, Url's and or part numbers for the bits I will need. I am going to replace the standard valves with TRV's? (Thermostatic) and can you recommend some cheaper ones that work well? I will need 5 in total so around Ā£10 eat would be great.
I will need help with replacing the draining valve downstairs but best to not make this initial post too long.
Best Wishes and Kindest Regards
Carl.
I for one feel like I'm attending a DIY Plumbing course reading this post.
Very detailed I will grant you.
You need to either use an olive cutter, or cut through it with a junior hacksaw ( skill needed, if you nick the pipe your up the creek or can be), try putting a spanner beneath it first and gently tapping it to see if it will come off, sometimes you're lucky. You can normally see if it has been over tightened to be honest, if it has, cutting is the only way.
Hard to say off that pic. Best bet is for you to go look in the loft. It could be something else like a cold feed to a bath? I cannot see it well enough on my screen, others may!
I don't know what a URL is.
I would only use a decent make like Danfoss. They do different models but any good Plumbers merchant will advise you. You don't need part numbers and if you needed a URL, I would know by now.
I think it may be a record already lol.
I see you are confident?
Are you well practised at Plumbing or is this a first?
Before I read the replies, I thought same as the others. The OPs wording suggests he would be better getting a heating guy in to do it. It would be the simplest job to a pro and only a few minutes work. I could replace those valves, including nuts and olives, without draining the system. It is one of those jobs I would like.
They are Conet rad valves and have good quality nuts and olives, but terrible valve body as the rubber packing seal leaks and the plastic head breaks easy.
Carl do yourself a favour get a Plumber in for couple of hrs to do your valves and replace the 2 Red handle valves in your airing cupboard for full bore leaver valves, don't forget to put inhibitor back into your heating system
Thank you very much for your response. The advice you gave about the olive and the spanner will be my first go to.
I have heard about cutting into the olive with a hacksaw and although if I nick the top of the copper pipe, its not the end of the world because and I suppose, I would have to cut it anyway, if I can't get the olive off. And if worse comes to dbl worse, I could always cut the pipe lower down, install a connecting piece, then put a new bit of pipe in the top?
I suspect that if I do have to cut the pipe, it will then be a case of me doing the same the other side and then lowering the Radiator mount an equal distance. Then it should fit as normal. If I'm lucky I could route out the the existing mounting brackets (if there is enough metal to increase the depth of the grooves)? As they are in place and disturbing them would be a nightmare. I have metal studded dry walls. They don't like raw plugs.
No never done plumbing before, really nervous about this frankly hence why I'm here getting as much help as I can before I flood the house.
I have spent the whole of yesterday watching youtube videos, which has given me everything I know so far. Plus a very kind guy from Grahams plumbing. (Sorry that's not an advert and I can remove it if it offends anyone). As long as I cover my back (know about the main riser and have lots of buckets on standby), things shouldn't get too drastic.
And of course with you guys helping, I should be in good shape.
If you have the time here are some more pics fo the airing cupboard.
Best Regards
P.s, I'm dyslexic and with Asperges. We seem to be quite linear thinkers hence the way of cataloguing but have trouble containing the amount of information ;)
Not taking the mick Carl , but your post made me laugh , you now know why we charge what we do .
Good luck with it .
Well the last plumber put that awful drain valve in. Didn't secure a radiator properly and left the thermostat valve on the frost stetting, so I come home during winter to find the bottom floor flooded. Just after I'd laid laminate flooring.
I've had every cowboy from here to Texas in, so now I'm doing it myself.
Obviously I make no general comment on Plumbers or tradesmen, perhaps I have just had bad luck or am prone to picking the wrong type of ppl, or not standing up for myself when it all goes wrong.
But thanks, I agree with your post entirely. I would actually like to be much more knowledgable on plumbing so this seems like a great opportunity.
I don't mean to be rude and of course shoot myself in the foot but isn't the point of me taking all this time to open an account here, make a fun avatar, start a long thread that took me a few hours to put together, be, so that someone with knowledge in return, imparts some to me lol??
How would you do it without draining the system, is it by freezing the pipes?
And what are you referring to in the last paragraph. The Conet rad valves. Are you telling me to not use them and are they the valves for the radiator?
I would of course be in a better position to pay a plumber but have had a bad run with tradesmen and am currently refusing to have anymore in. The last one flooded my house and now I don't have the money anyway to pay anyone.
Unless you live in pompey and or are happy to do it out of good will, the next best option is to help me here :)
but I understand your knowledge has been earned and shouldn't be given away free which then asks, what is the point in this forum for DIY enthusiasts?
Anyway I appreciate your response and thanks for taking the time to respond. You didn't have to.
Hi, thanks for the response. I actually cannot afford to pay a plumber currently and without taking the radiator off, I cannot decorate the room.
Thanks for the tip on the the full bore valves. I assume they are the ones you get on say gas pipes, with a handle as opposed to a wheel?
If the gentleman who knows how to replace valves without draining the system can tell me how, I might get away with only having to add inhibitor back into the two radiators I will have drained, instead of the whole system.
Anything to save me going into the loft.
Cheers.
Looking at the last set of pics Carlton, I am fairly sure that the pipe you labelled 'Heating valve' is not for the Heating. I suspect it is a cold feed to something. I may be wrong because I'm going off photographs.
You need to look in the loft for an isolation from the F+E tank or, drain the heating after you have turned the mains water off.
It is - as everyone is saying - a very easy job for a Plumber and you would be best advised to employ one. However, if you would rather try it yourself, that's fair enough.
The Gentleman (@Best ), who said he could do it without draining down has a wealth of experience on his side. I personally think you would be safer draining it off if you're inexperienced at Plumbing.
No offence meant, it's just that if it went wrong it could make a mess.
The old valves are Conet and probably not made any more. You really just need decent replacement thermostatic valves on most of the radiators and also replace the other side. You can get TRV with a lockshield packs of rad valves.
I do not freeze pipes, but do it a different method, but you will be best to just drain the lot, as Last Plumber said. I don't want to have you getting into bother and causing water damage.
I would have had all your valves replaced quicker than you typed your post no doubt, but I have been doing that sort of work regularly.
It is a shame you haven't found a plumber you have confidence with. It doesn't surprise me, but there will be some good plumbers out there if you keep trying.
What do you think would be a good way to go about checking?
If I turn the heating system on and the pipe gets hot, would that be a good sign its not a cold feed and if doesn't get hot it is more likely as you say, a cold feed (which is probably right).
Seems like a hell of a mess of pipes lol
I agree I was probably more curious about his method. Being somewhat of an autodidact has that effect.
When I drain down in the next cpl days, I'll make sure I turn the whole system off.
Will be great if I can avoid getting into the loft but I also know that adding Inhibitor is easiest done in the tank, although apparently not as good as adding it to the rad itself.
I will have 5 radiators to do in total so I can see the drain down being done several times, over a few days. Probably best to add the inhibitor at the end when I'm done.
Thanks a lot for your responses.
Thanks for the info. I agree with you 100%, it will be the safest option to do as you say.
Again it really is a case of money. Paying someone Ā£100 I don't have when i'm saving that for a 3d printer seems like an impossible choice.
Besides it will be nice to be more like my dad who seems to be able to fix anything, including pipes, electric, cars, you name it. Mans got to be a man so to speak.
Im hoping you guys will help guide me as I go. I will keep you up to date with whats going on and it may come down to slipping you a drink over PayPal for a bit of face time if I get really stuck.
I was going to go with these valves as a replacement although I know 'Last plumber' recommended another brand, I haven't looked into those yet but will do in a min.
What do you guys rec?
They are Ā£10 for a pack including lock shield.
Altech Angled TRV with L/S Valve 15mm White Pk 2 - Radiator Valves & Accessories | Graham
The only reservation I have with these is that they only work from 7 degrees upwards. Although none seem to work below 0 degrees. I guess it's no big deal as you would rarely set your rads to below 10 anyway right?
Also do you have any better recommendations for TRV packs off the top of your head?
And lastly (sorry) the adjustable side on the radiator I pictured is on the right hand side, which seems a little odd and annoying since it puts it into a corner, which would mean its ability to read a room temp accurately will be greatly diminished. Can I swap the sides over? (I'm going to assume the answer is no and bring about some merriment from ppl who know even the basics of pluming, which I clearly don't lol).
Thanks in advance.
I found these for Ā£15, nice looking and perhaps as you say, good quality. Certainly look a little better than the Graham own brand i listed above.
Danfoss RAS-C2 straight TRV and lockshield pack 15mm | Plumb Center
I also need to check my pipes are 15mm.
Ahh (edit to post) I just noticed the adjuster seems to be hanging off the side of the pipe work. TRV's should be fitted horizontally for the best temp read away from the rad but I also don't see the shield in this pic. Will need to look into this.
I have heard some say that having the adjuster horizontally makes it easier to get knocked and thus leak.
Your thoughts?
2nd edit, I don't think these are right for me, they seem like what you might call 'in line' as in the pipe is horizontal to the radiator not vertical like mine.
I will try to find others fro this company.
Redecorate the wall, clean up those radiator valves with metal polish ( or even respray them with a chrome spray) and then at a later date (summer?) employ somebody who'll have the right tools and who knows what they are doing. It's a relatively small job that shouldn't cost too much in labour and you've already wasted hours posting here already. As very practical folks that are used to problem solving we get a sense of a persons ability and it would be fair to say given your posts and the responses given that no-one else has a great deal of confidence in your ability either. Please take heed of the advice given and get someone in if you insist on renewing those radiator valves, if you get yourself into trouble what we fear most is your ability to get yourself out of it.
The Altech valves pack are inexpensive and in my opinion as nice looking as any valve and seem good enough quality. They are also fully compatible with most other high chromed standard valves, so easy to swap the valve bodies in the future.
I have installed some of same valves and so am speaking from my experience of them. Time will tell if they last well.
The Danfoss valves are a well known top quality brand and probably a good choice. Note that the Danfoss bodies are not the same as normal valves, plus pipes depth of Danfoss valves are less, so wouldnā€™t be just a direct swap to another brand body if ever needed.
Another quick tip if you cant get the old nuts & olives off the pipe you could check to see if new valves fit the old nuts quite often they do so if your happy to leave the old nuts/olives in place do that.
I appreciate your concern and for now I am going to fix the wall and pop the radiator back on, hopefully without leaks (having disturbed other joins along the chain).
However I would like to teach myself some plumbing and that is why I'm here.
You claim I'm wasting my time writing but it's only because you aren't giving me any information. You are essentially creating a self fore-filling prophecy.
Perhaps the best way for me to not waste my time and for you to not waste yours in turn, would be to help teach me how not to, get into a bad situation.
So for example, you could tell me, drain the system first, that will stop flooding.
Putting a hose on a drain valve that is controlled prior to its fitting by the valve on a radiator and at worse shutting off the mains riser and if that doesn't work, having the mains in the road ready to be switched off, is a sensible approach to not flooding my house.
I mean how many more things in a chain have to go wrong before even a pro plumber will be panicking? I mean all of them would have to simultaneously have to go wrong, including the street valve malfunctioning. I think that's highly unlikely.
If I get to the point where I cannot turn off the mains in the road, then what would a plumber do anyway, apart from have insurance, which I already have.
It's not like Im trying to take off the mains riser tap here or install new valves in my airing cupboard. Im simply trying to take off a radiator and change the valves.
Im good at picking up information, Im careful in what I do and I watch hours of youtube videos and read tons of stuff before doing so. If I think something is too risky, I wont do it.
Everyone else here is being pretty damn helpful and have already given me due warning and probably sage advice on getting a pro as part of their input.
If you still think I'm missing anything then with respect, please help me by telling me.
Regards.
Interesting!
The bodies do look a little different. I am aware that the piece that goes into the radiator needs to be as close to the valve body as possible to get the best seal. I will buy both sets and offer them up, or take measurements of the length and reach (into radiator) of both.
I actually prefer the more high chrome look of the first choice over the slightly duller look of the latter although will compare internals and warranties. The Danfoss only offer 2 year but have copper inserts.
Thank you very much for this info. Very helpful.
Great tip JTS but those nuts look pretty bad. I have tried cleaning them up with wire wool and didn't get much success. They seem to have pitted in places beyond repair (for decorative purposes).
The olive is going to be the real bugger on this, I know it but I think I will be able to get them off without damaging the pipe, if I'm careful.
If I do have to cut the pipe I am correct in assuming I can simply lower the radiator by an equal distance or do radiators need to all sit a certain height?
Would be interested to know. Although I could probably simply go upstairs and measure the height of them all lol
It's funny how much you can work out by simply typing the question. Once the idea gets out of your head and onto paper (paper lol), the answer becomes much more obvious, or at least a solution to it.
Regards.
Those TRV packs are ok. Will do the job. You donā€™t want them turning down to zero as this is frost protection should temperatures really plummet. As long as the valves are bidirectional it doesnā€™t matter which way you have them round
Thank you for the input. Could you explain why bi directional valves make it ok to switch sides. I do believe you, I'm simply curious as to why it works.
I haven't yet fully understood how the heating system works. For example, one radiator doesn't lead on to the next because i can take off a radiator and still keep the heating system flowing.
Obviously this means there are pipes that carry the heating system past the radiators regardless of their connection but I simply haven't designed my own system and therefore cannot seem to fully imagine or understand it.
Do you have any good literature to hand?
Or know any software programmes that allow you to make such a simulation?
Regards.
You can buy an olive splitter.
It will split the olive without damaging the pipe. Monument do one that looks similar to a metal clamp. But the cost of buying it would pay a plumber. :)
Bidirectional means just that. You can have it on the flow or return side so water can pass through it into the rad or out of the rad through the valve and they will still give you heat control.
Sounds like you will have a two pipe system a flow and a return carcass. Each rad will have a tail linked to the flow and one to the return meaning that should you shut off or remove a rad the hot water will still circulate to the other radiators. What you describe is a one pipe system and itā€™s best not to over complicate things with talking about that
I have prime should I grab it? And is this a good one? Obviously need to check my pipe diameters first.
Thanks for the tip. Ā£25 seems reasonable. And I will have up to a month to return it (obviously unused cough).
https://www.amazon.co.uk/Monument-2...=2025&creative=165953&creativeASIN=B0001P0FFY
The water will only go round one way however some Trvs only worked in one direction and as such needed to be on the flow side.
I think I was getting hung up on the idea that, if what regulates the radiator is on the exit valve then how does it regulate the radiator with a uni directional flow but it makes sense now.
Even if the water flows one way, the valve is measuring the room temp and the will shut the water off at the end not the beginning.
In effect the same difference just at a later stage in the process but with the same result.
And of course, the valve being bi directional means it doesn't matter which way the water passes through it, which then begs the question (for the more nerdy person), what made a vale uni directional in the first place. I would have though they all would be bi directional but obviously not.
Don't worry you don't have to answer that.
Cheers, that's been really helpful!
That isnā€™t the one I meant, although it will do the job. My mistake, - I should have said Rothenberger olive splitter, which looks like a little vice and I prefer it, plus it works on 15mm and 22mm and 28mm.
But the Monument tool will also work, but limited to one pipe size.
Thanks Best. I've popped it in my basket for when it comes to changing valves.
I would point out though that it only does 15mm and up, not under, so no 10mm etc.
It certainly seems better to have one of those than a purely dedicated width as you say.
Im also looking to move some pipes around. Could you suggest a cheap but good blow torch system. I see you can get heads that screw on to cans but the heads vary widely in price.
Im hoping for something around Ā£25?
P.s where in the uk are you based roughly?
Reply to Brand New To Forum Hoping For Help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
