Discuss Brass fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Use an empty inhibitor bottle, lay it on its side and cut a section out of it to catch water in.
If we drop the pressure on the combi to do a snatch changing the rad valve.How would i do it when there is a cylinder involved.Do i close the gate valve on the cylinder and the tank in the atic?
No. On an open vented system you use bungs on the feed and expansion pipes to create the vacuum.:)
I need to remove my rad from my bedroom because some numpty that lived in the house before us stood on the radiator while throwing things out of the window and pulled a rad bracket out of the wall.The problem is i have a low lying window ledge and the radiator sits low to the floor so i think getting a bucket in there will be near impossible lol
Thats what your thumbs are for. Close the valves put a couple of rags under the ends, split the nuts and lift it out full of water.
Never had the need for a wet vac in my life and i doubt if i ever will.
True old school :yes:
Put a new radiator on a combi system the other day and piped it in. Dropped pressure to 0 bar. Removed stop end to start soldering and water just came out loads of it so I'm assuming I didn't create a vacuum. The boiler was a woster botch 24kw small thing don't know the exact model but it was a new one. Does this have an intergated AAV? Explaining why the water was escaping.
Possibly. On a combi system though i see no reason not to drain down if not confident. Just bill for redosing inhibitor.....
Can drain and refill in no time:)
Reply to Brass fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello guys, a couple of months back I installed a new shower and sink into a part of the house that hadn't previously been plumbed in. This forced...
Where the black polyethelene service line enters this particular structure is by far the most freeze-prone area. The structure is an elevated...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
Hello. My home's Rheem water heater is dripping from the drain valve. It is strange as it seems to sometimes spit out some water and then stop...
Hi folks Really daft question here but what tap connectors are you all using? I’ve picked up a couple of end feed with fibre washers today and...
