Discuss Bristan 3 hole mixer in the USA area at PlumbersForums.net
Matt0029
Has anyone fitted this type of tap before?
Yes, fitted a couple, absolute pain in the backside. Never seems to be enough room to get all the bits in, connected and water tight.
I thought with being bristan they'd be good/ installer friendly? Take it, it comes with 300mm flexis for the connection between the spout and the tap valve? And you have to loop them over.
I dont think they're even 300mm in length. It will all depend on design of basin and whether you have the basin insitu or it's a new install and you can work on it before the basin is installed. Although it's not much easier on a new one.
Reply to Bristan 3 hole mixer in the USA area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
