Discuss Bristan 3 hole mixer in the USA area at PlumbersForums.net
Matt0029
Has anyone fitted this type of tap before?
Yes, fitted a couple, absolute pain in the backside. Never seems to be enough room to get all the bits in, connected and water tight.
I thought with being bristan they'd be good/ installer friendly? Take it, it comes with 300mm flexis for the connection between the spout and the tap valve? And you have to loop them over.
I dont think they're even 300mm in length. It will all depend on design of basin and whether you have the basin insitu or it's a new install and you can work on it before the basin is installed. Although it's not much easier on a new one.
Reply to Bristan 3 hole mixer in the USA area at PlumbersForums.net
Hi, As I need to purchase two new taps for our en suite, I've noticed that almost all taps now come with flexi tails as standard. I've read some...
Hi All As you can see from the attached pix, the flow control knob on my Bristan shower has broken. It was installed before I bought the house...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Hi I've seen a previous thread that is closed now regarding this subject but the end result I could not see. Our Shower runs hot for 30 seconds...
