Discuss Burst pipe in my flat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have currently had a burst pipe in my flat, I was going away for a long time and I was trying to turn off my main water supply for the flat. I have a unvented cylinder system.
First, I turned off the switch for the cylinder, then I turn the handle of the three shutoff valves (one is above the cylinder), but after a few hours I was told that one of the pipe bursted....
I just want to know why and what did I do wrong.....
Guess you didn't turn the mains off
This is the picture of the cupboard, the red lever i turned off
Left brass stop tap is your mains stop tap
You probably won't of been able to turn it any way very stiff need tools
prob wont turn the hot water off but it could of been a heating system leak without knowing hard to say
Reply to Burst pipe in my flat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Morning everyone, if anyone could please offer advice on this issue it would help me with a massive issue regarding the water supply in my flat...
Where and how does the water supply work and is there only one rising main pipe and where is it usually located? I am top floor flat, mains fed...
Background I have a small one-bedroom flat in the roof space in a victorian house. There are three floors below and each floor has a single...
Morning. I have a leak. It’s coming from the connector pipe….the picture shows the pipe. It is a cold water pipe going in to the back of my...
