Discuss Buteline from 15mm pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
JohnthePainter
I've been reading a lot of good things about buteline but a few things have me confused...
1. How would you transition from a 15mm setup (under sink for example) to a Buteline setup? Seems like the only do 10mm (surely too small), 16mm and 22mm?
2. What about isolation values etc? Is the idea that this then goes to a copper pipe fitting for isolation values?
Thanks! Just a bit confused...
Maincor is a better system in my opion i have used it on a timber frame new build excellent for those sort of jobs great for under floor heating aswell check it out cheers kop
Reply to Buteline from 15mm pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
