Discuss Calydra comfort 100 No hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pete little
I have a Calydra comfort 100! THe central heating works fine but the hot water side does not fire up!
I have changed the 3way valve ,pcb, when i switch on tap i get the 60 70 80 leds on lack of water circulation!
any ideas please! pete.
never heard of your boiler ... however if it's a combi it sounds like your plate heatex could be blocked if there's an issue with circulation.
Hi , thanks its french made by chaffoteaux & maury! can you tell me what the plate heatex is please
Pete
It's the thing that transfers the heat from the circulating water to the water coming out of your taps! Situated within the boiler, the diverter valve diverts water through it when there's a demand for hot water :) Also known as the plate to plate heatexchanger, hot water heatexchanger or secondary heatexchanger! Is the boiler a combi?
yeh , its combi, its about 7 yrs old is it worth changing the hot water exchanger?
Hey pete :) 7 years old isn't that bad an age for a heating boiler! If it is the plate heatex then that's all it'll be! may be worth lookin into the reasons why though? Could be dirty system or hard water? Either needs addressing IMHO :)
Hi steve , the problem started when running baths! it would only run for 5 mins and we got an overheat light would come on! would the water throttle cause a prob like this? or should i change both?
thanks pete...
Hi, did you resolve this problem?
i have the same problem with the 60 70 80 LEDs indicating lack of water circulation,
many thanks!
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location - [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - http://www.ukplumbersforums.co.uk/users/8668/ or Redsaw - http://www.ukplumbersforums.co.uk/users/2718/ who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/ce...ed-advice.html (notice gas safety related advice)
Reply to Calydra comfort 100 No hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
