Discuss Camray 5 oil burner warning lights meaning in the USA area at PlumbersForums.net
Need help deciphring these lights on a camray 5 oil burner.
What do they mean ?
I can't get the flow to heat up the water storage cylinder . The motorized valve won't open . Any ideas or suggestions on the subject ?
[automerge]1588106893[/automerge]
What do they mean ?
Camray 5 should be a combi. Has the hsa3cd actuator head which is a special.
What lights you on about. Have you reset the high limit? Any work been done on it?
Reply to Camray 5 oil burner warning lights meaning in the USA area at PlumbersForums.net
