Discuss Can anyone help me identify this system? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Went to apartments with this set up. It's got an 18l expansion vessel. To pipes out the top. 2 central immersions going into the fuse board on the front. A pipe coming out midway with a grunfoss pump then goes back into cylinder. 1 pipe with pump(central heating) going into it.
There's a 2 channel programmer. It can't see any zone valves anywhere? Anyone familiar with this?
Looks like an electric thermal store.
Hit wTer goes through a coil and heating is pumped direct from the cyl.
Is there a header tank on the top?
Not a Church Hill set-up is it? I'm sure someone else posted about one of these this week....
thermal store with heating water in the cylinder and hot water in the coil
pressurised both sides
Reply to Can anyone help me identify this system? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Background 24 apartments are equipped with thermal stores of (100 to 150 litres) with immersion heater capability. Individual demand of each...
Hello, I have just installed a vented McDonald 250L thermal store, it is for multi fuel but currently just connected to a standard oil boiler in...
1K
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
Ideal Logic Heat 15 System Boiler Hi. Just started to get an F3 Fan Fault on this boiler. On power up there seems to be a quiet thump from...
Deleted member 120897
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
