Discuss Can anyone identify this bifold door pls? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
This is from around 2010. It's got a cross-hatched border with a floral motif. Can anyone identify it pls? Need to replace some of the the pivot-related parts...
Cheers.
The reason there is no manufacturer name on it, in this case, is because they are too embarrassed to own up to the poor quality of their product.
Do yourself a favour and replace the whole thing.
Mine failed at the same point, the plastic simply fails with age, Fordhams was the original make, but to be honest, as already suggested, change it for a new one.
I swopped mine out last week and it’s easy enough to do.
It looks quite tight, but if it’s feasible to use I would replace it with a pivot door.
It only has to be able to open enough to get in and out - the doors are far more robust than bifold.
Reply to Can anyone identify this bifold door pls? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
