Discuss Can I cut a shower tray? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hey there,
I purchased a black slate shower tray from a supplier. The supplier recommended that we cut it down to our required size. Is this good practice/possible? Some plumbers I speak to say absolutely not to. Others seem OK with the idea.
I hope to cut it down to around 1600x700. Cutting the width seems to be a problem with some since it will place the waste off centre. Im not sure if this is a practical concern or just a visual one?
The tray is a KRISTAL SLATE 1700 x 800 Shower Tray in Black.
Any advice welcome, thanks!
I'm skeptical – ask the supplier to provide a 'Methods Statement' for safely and accurately cutting the tray or talk to someone who has actually done it successfully.
If it's possible, can't you take 50mm off each side to keep the drain in the centre? It's going to look rather amateurish if it's 100mm off-centre.
I have a feeling that the minimum width permitted by building standards for a shower cubical is 760mm. I recommend that you check this point before committing.
You need to be talking to a tiler about cutting the slate tray, cutting is a major part of their work.
Better still take it to somewhere that does granite worktops cutting, they'll have a saw suitable for cutting that size.
If the tray has a lip around the edge you'll need to cut all 4 sides and cut the lip off otherwise it will look odd.
Is it like this?
Reply to Can I cut a shower tray? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Do you recognise this shower drain rubber seal? I have searched the web and common plumbing spares suppliers but I cannot find which it is. It...
I have bought a replacement 1200 shower door & 1200 x 900 tray, ready for a refurb starting soon. The current door & tray is in a recess, which...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This...
Hi, I am looking to install a Mira flight shower tray 760 by 760. I would have like to have removed the existing floorboards and installed battens...
2K
Hi there, I'll soon be installing a SONAS 1500 X 800 resin shower tray in a bathroom that I am renovating. It does not come with any sealant or...
2K
