Discuss Can I replace this sprout? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I need to replace the sprout of this faucet. Is it possible to unscrew and change just this part? It has a tiny hold due to rust and water leaks out from it.
Reply to Can I replace this sprout? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
