Currently reading:
Can I use PEX pipes for hot water cylinder?
Discuss Can I use PEX pipes for hot water cylinder? in the USA Plumbers Advice area at PlumbersForums.net
UK rules.
Can I use PEX/ PCV/ plastic pipes instead of copper, when I replace hot water cylinder?
I want to replace old Tribune model with new Megaflo, both are unvented direct cylinder.
With new unit comes combination valve and all the bits and bobs.
Can I replace existing copper pipes that goes from combination valve into cylinder (at the bottom)
Also the hot water output (on top of the cylinder).
Please advise.
no I'm DIY.
Best get a pro / qualified person in as they need to be installed correctly
You need somebody who is g3 trained, if they are a member of a competent person scheme they can also sign off and notify building control.
Its legally not a diy job.
On a personal note I would stay clear of megaflo.
In the end I'm fine with qualified plumber doing that work!
I'm looking for ideas / proof of concept!
What's your concern regarding megaflo?
System is unvented & direct.
I like the idea of expension vessel integrated into cylinder.
I have restricted space in cupboard.
Please advise.
Please advise.
Proof of what concept?
Megaflo overpriced for what you get. Other manufacturers do internal bubble.
Reply to Can I use PEX pipes for hot water cylinder? in the USA Plumbers Advice area at PlumbersForums.net
