Discuss Can I use PEX pipes for hot water cylinder? in the USA area at PlumbersForums.net
UK rules.
Can I use PEX/ PCV/ plastic pipes instead of copper, when I replace hot water cylinder?
I want to replace old Tribune model with new Megaflo, both are unvented direct cylinder.
With new unit comes combination valve and all the bits and bobs.
Can I replace existing copper pipes that goes from combination valve into cylinder (at the bottom)
Also the hot water output (on top of the cylinder).
Please advise.
are you g3 reg / qulified ?
no I'm DIY.
Best get a pro / qualified person in as they need to be installed correctly
You need somebody who is g3 trained, if they are a member of a competent person scheme they can also sign off and notify building control.
Its legally not a diy job.
On a personal note I would stay clear of megaflo.
In the end I'm fine with qualified plumber doing that work!
I'm looking for ideas / proof of concept!
What's your concern regarding megaflo?
System is unvented & direct.
I like the idea of expension vessel integrated into cylinder.
I have restricted space in cupboard.
Please advise.
Please advise.
Proof of what concept?
Megaflo overpriced for what you get. Other manufacturers do internal bubble.
Reply to Can I use PEX pipes for hot water cylinder? in the USA area at PlumbersForums.net
Sonya K
