Discuss Can I use PEX pipes to feed a default radiator? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm pretty much a novice at DIY, fitting a Charnwood Country 8B woodburner with a back-boiler which puts a maximum of 7kW into the water, and the default radiator is 1.335kW.
I'd like to use 28mm PEX pipes, as they're so much cheaper than copper; but I don't know whether it's safe to do that.
Anyone got experience of using PEX as central heating pipes, and did you use them for the default radiator?
Hi im sure other replies will say the same dont bother if it all goes wrong or you make a mistake, its to much of a risk to personal or property.
Pex can't be used with any solid fuel appliance
Having taken your advice, I've bought copper and am about to fit it; but I have a couple of stupid questions. (Actually, more than a couple, it turns out).
Firstly, PTFE tape. Is it worth it (a lot of people recommend it; but many say it makes no difference. Who is right)? Is it stable enough to be used on the piping for the default radiator? What about the fittings on the back of the stove? Intuitively it seems to me that no part of the stove directly connected to water should ever get above 100 degrees, so PTFE tape would be okay. Is that right?
Secondly, one of the plumbers we had in to quote suggested that we could handle filling the system, and dealing with overflow due to expansion, by teeing off from the default radiator flow piping, into a small tank with a ball-cock inlet, and overflow pipe outlet.
That seems entirely reasonable, but I've never seen anyone else suggest it.
Am I missing something?
Reply to Can I use PEX pipes to feed a default radiator? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I'm really stuck with an issue I have with our soliud fuel back boiler system and my novice understanding is pretty much out of ideas so...
6K
Hello all. I'm new to this forum and need some advice about some concerns about a new gas boiler that I have had fitted by a gas safe engineer...
4K
UK rules. Can I use PEX/ PCV/ plastic pipes instead of copper, when I replace hot water cylinder? I want to replace old Tribune model with new...
4K
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
H
HRP123
H
