Discuss Can Power flow flux go off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
It might do.
I use laco, and when you get yo the bottom of the tub it seems to not be as good as a new one.
It is probably essential to stir the entire contents of the flux tub often.
Anything that can melt or settle in its container really should be stirred I guess.
The chemicals in it likely separate and the flux will not work right.
I know the grease based Traditional fluxes need stirred if hot weather heats the tub in van.
yes if it goes yellow if off white your ok
If you are not sure...take a dab and rub it on ua balls..if no sting ...gone off...if stings like hell..at least you know you are good for 100 more fittings......
:86:
:86:
or even better rub it in a cut :D
Reply to Can Power flow flux go off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
We have 2 brand new cordless, battery powered press tools in stock, and flying off the shelves. Our TekTools TZ1930 & TZ1550 are packed with...
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
