Discuss can you bend 15mm coated copper in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yes (by coated I take it you mean plastic)
but you will need different former & slides or think they do an external spring.
yes you can and normally a sparks bender will do, but there are special ones out there for plastic coated
Bends can only be pulled on the ends of each length of pipe if that suits the installation then fine otherwise you would have to make a joint.
Thanks and I guess you won't be able to see any rippling :). Joining coated and normal copper is not a problem?
Is this plastic coated going in as new then James or is it existing & you are just coming off it with R250 (for the oldens Table X) cos you could use 15mm plastic coated soft copper R220 off the coil & bend it by hand ?
No problem joining together BTW.
Reply to can you bend 15mm coated copper in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
