Discuss Catering Flexi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
leej
Good One For You's
Do you need COMCAT to replace a catering flexi on a commercial appliance ?
Is it classed as the appliance or the installation
Thanks Lee
comcat required, and depending on pipe size core commercial as well. you only need the comcat because you have to commision the appliance after you have changed the hose.
That's the view we have taken on it as a company but caused a bit of debate amongst our engineers,
Reply to Catering Flexi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
