Discuss Central heating cleaner removal in the Central Heating Forum area at PlumbersForums.net
Can anyone offer me advice, I’ll try and keep it short!
Just cleaned my magma cleanse unit, and it wasn’t too bad since last boiler service 1 yr ago. I have had a blockage in a microbore pipe which has been cleared. For piece of mind I thought it would be a good idea to add some MC3+ cleaner. Once that had been in system for approx 1 week is it ok to drain down system, refill and run for say 1hour, then drain down, refill and add MC1+?
Will above remove enough cleaner to enable MC1+ to work? Or does system have to be flushed?
A bit of residual cleaner left in the system isn't going to adversly affect the PH of any inhibitor added later. By all means rinse the system if it's particularly dirty but if it isn't I'd just refill it and add the inhibitor.
Thank you thats good to know. In my case I removed the cleaner by systematically going round each downstairs radiator that had a drain valve on whilst leaving the system filling up in the header tank and the central heating 'on' and circulating. I did this as previously when I drained the system fully I had terrible problems with air locks on filling up. Unfortunately a few radiators dont have drain valves so I did not drain these, I guessed as I left the central heating on and circulating it would sort of get the cleaner out!
Took me all day so there was a lot of water flowing !
Was my theory flawed!
Thank you.
Sounds like an awful lot of agro and water. Might be worth installing a drain cock and auto air vent or two.
Yes it was very time consuming and used a lot of water (and I am on a water meter!), but I thought I had the time to do it.
Thanks for the advice about the drain cock and auto air vents - will look into these.
Reply to Central heating cleaner removal in the Central Heating Forum area at PlumbersForums.net
Hi all, Got a nightmare situation with a central heating system I recently adopted. It's an open vent system with a combined F&E pipe, with a...
2K
My father has a parkray fire which has a back boiler . He had a leaky radiator, when he was attempting to fix leak the circulating pump...
RobinA
R
Hi The onslaught of plumbing questions continues! Sorry folks... The plumber is coming on Monday and will be draining down to do the bathroom...
2K
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
Not sure how long this has been happening but some symptoms have been there a while - only noticed now as the house is cold in this weather plus I...
