Discuss CH pump leaking even after replacing in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have a Grundfos pump attached to my UFH manifold. Noticed the floor boards below were warping and that it had been leaking ever so slightly for some time. Removed it, cleaned seals etc, tightened back up, leaked.
So bought a replacement (UPS3), with new O rings and it leaked again. Retightened this time adding a bit of Fernox to the thread but it still leaked.
Thinking potentially the threads on the female brass ring have gone (maybe from over tightening over the years) but any other ideas?
Is it definitely leaking from the threads any stuff on the face of the brass ?
Reply to CH pump leaking even after replacing in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
1K
… praying to the plumbing God, Bob Pictures and layout details attached, so be patient. 21 year old oil fired system in pretty good nick. I...
1K
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
1K
N
I had my old boiler replaced and changed to an unvented system and relocated into the loft. Everything worked well for the first month or so. I...
1K
Novice needs help
N
Hi, Solar thermal not so big these days but a couple of Q for anyone who still works in it. Background. I'm an Electrician not a plumber.. I've...
