Discuss Change bathtub drain/flange without access under bath in the USA area at PlumbersForums.net
Hi was wondering if it was possible to change my bath drain as it has gone a little rusty but i don't have any access under the bath as the side of the bath is tiled in.
It looks as if it would just unscrew an pull out but im worried about it disturbing the rest of the drain and ending up being a big job.
Thanks Adam
in theory yes you could but theres a few things that could go wrong eg pipe dropping so you loose the plastic bit on the underside
something could snap or the screw might break / not come out etc
tbh if it was me and you havent access i would leave alone, on another point you should have access so maybe a though for the feature
Reply to Change bathtub drain/flange without access under bath in the USA area at PlumbersForums.net
Hi, I have a few issues with my bath drainage and leaking. The first issue is that the near corner of the bath by the taps is sloped downwards...
Good morning! First post looking for advice on an issue I am having with a bath installation. Although I have installed many baths before, mainly...
Hello All, Hoping for a bit of advice/info in this one: My Setup Small system in apartment with cold tank above hot tank in the hotpress, so...
2K
Have one radiator still not working despite whole lot new now and was the only one tepid before all changed and don't really know if drain valve...
3K
Hi, So I have a close coupled toilet and all the screws and everything are totally inaccessible. A few weeks ago the cistern started to leak into...
2K
