Discuss Change bathtub drain/flange without access under bath in the USA Plumbers Advice area at PlumbersForums.net
Hi was wondering if it was possible to change my bath drain as it has gone a little rusty but i don't have any access under the bath as the side of the bath is tiled in.
It looks as if it would just unscrew an pull out but im worried about it disturbing the rest of the drain and ending up being a big job.
Thanks Adam
in theory yes you could but theres a few things that could go wrong eg pipe dropping so you loose the plastic bit on the underside
something could snap or the screw might break / not come out etc
tbh if it was me and you havent access i would leave alone, on another point you should have access so maybe a though for the feature
Reply to Change bathtub drain/flange without access under bath in the USA Plumbers Advice area at PlumbersForums.net
