Discuss Choosing the right shower unit? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
calibra
Hey guys,
New to the forum here and have been browsing around quite a bit here. Great wealth of info. Thanks.
Anyway. I need some advice here. Looking to buy a new shower unit for our bathroom. In our house the water is gravity fed via a cold water tank in the loft. I think it's around a 50 gallon judging by it's size measurements. Now as our water pressure in the bathroom is quite low I am looking at get an Electric Integral Pumped unit that will feed off the cold water alone.
Browsing around the net I have found a few potential suitable units listed below. However I need some advise/opinions on which make/model is probably the best the go for. I've also heard some integral pumped units are more noisier than others?
Triton T150Z Pumped Thermostatic Electric Shower 9.5kw
Mira Elite ST 10.8kW Electric Shower
Thanks.
HI
Why can you not use a hot water service which would give you a greater range of choice in models and manufacturers, But having said that I would always go for Aqualisa as a quality product but if you ask ten plumbers you will get ten different answers
regards
Grumpy Old Plum
Aqualisa digital gravity model is a good shower have fitted plenty
Mira built in power showers have given very good service for years IMO.
Reply to Choosing the right shower unit? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
