Discuss Cistern lever: 3/8" bush means 17mm? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have bought a cistern lever that is described as having 3/8" bush According to the salesperson, the 3/8" refers to the diameter of the large white plastic threaded shaft which passes through the hole in the cistern.
But when I measure the diameter of this large white plastic threaded shaft, it is 17mm. 17mm is NOT 3/8 of an inch! 3/8" is 9mm.
So, what measurement does the 3/8 inch actually refer to?
Apparently most cisterns are made for 1/2" bsp thread on the lever, but Ideal Standard use 3/8".
As has been said, the imperial measurements relate to internal bore of the pipe, and the thread o/d's are as below:
if the actual hole in your cistern only measures 3/8" then neither of the standard sizes will fit!
Reply to Cistern lever: 3/8" bush means 17mm? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
