Discuss Cloak room basin in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Z
Zammo1001
Hi all,
I have bought a cloak room single tap basin that only stands 300mm off the wall which is fine
The problem is i bought a single lever mixer tap with pop up waste and when i have put my locking thread which you tighten up the tap against and the two tails it does not go through the 33mm hole in the basin
I am off to search out a tap which has the locking thread and tails tighter together but i think they will be the same
Anyone else had this problem
Regards Nathan
It sounds very tight but try undoing the tails and feeding them up through the hole to screw into the base of the mixer. It's a bit fiddly but usually works as the slimmer ends of the tails are going through the hole.
Good luck.
Reply to Cloak room basin in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have just replaced the old bathroom basin mono mixer taps, 2 tap heads, standard compression valve type, to a modern mono mixer single lever...
3K
Hi everyone, I recently had a Hansgrohe wall mounted single lever basin tap and a Hansgrohe thermostatic concealed bath/shower valve installed...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
Hi everyone, Is this set up correct: Attic stop valve turns off the cold water to my bathroom (I think it is the rising main in the attic which...
Hi. I'm looking for a bit of advice. First, I'm not a plumber, 2nd it's not a house, it's on a boat (probably doesn't make any difference). Maybe...
