Discuss Close coupled cistern - bits of debris in the USA area at PlumbersForums.net
I am about to re-unite a cistern with the pan and notice it has a few smallish (pin head size) bits of clay around the whole where the donut will go. They appear to be bits of clay fired on to the cistern.
simple question - should I sand them off? I have a new donut that’s identical to the old (which did not leak) but I’m paranoid about theses things. I’m guessing it can do know harm?
Yep sand them off
Reply to Close coupled cistern - bits of debris in the USA area at PlumbersForums.net
Hey Guys I’ve noticed this weekend that my en-suite toilet pan water level is seeming to regress after an hour. Toilet flushes as normal and water levels are all fine in the cistern. If I flush the toilet and wait all looks fine. However after an hour the water levels have dropped by a couple...
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled toilet with a more affordable model. This new toilet is a back-to-wall type featuring a concealed cistern within a separate unit. Since its installation...
Hi, I have a noisy cistern that appears to be leaking into the pan a little but also making a very frustrating water noise from inside, I have attached a picture of the offending item that is dripping water constantly. Guessing the whole lot needs replacing but not sure what to ask for when...
Hi - I have an old (maybe 45 year old) Twyfords Close Coupled toilet. The cistern has cracked, and I'd like to replace just the cistern. I'm struggling to find anything described as a close coupled cistern which doesn't have the bolt holes. I was hoping to find one with no bolt holes and just...
1K
Hi ive been asked to fix a leak on a flush pipe. I’ve never come across the pan type before. It looks like a closed couple but has a short flush pipe at the back. The pipe was clearly cut too short. it appears to be a 2” flush pipe going into the cistern but I looks like it’s 1 1/2” going into...
1K
