Discuss co/co2 ratio for lfe fires in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I don't bother unless the manufacturers want it done! Spoke to gas safe about this when I came across a boiler with no sample point on the fourth floor, which meant scaffolding to take a reading, they said its only mandatory on any appliance when the manufacturer stipulates. So it should say in the instructions if it doesn't mention it then it's not needed!
So if M.I.s state a reading must be taken, you've got to get a scaffold set up?! That's gonna be an expensive service!!
Nope if M.I.s state it must be taken a sample point will be present if it's not someone has probably installed the wrong flue!
With the exception of a fluless fire the FGA stays in the van.
A standard fire is designed to burn bad to give a good visual picture and your FGA readings will always be all over the place.
Reply to co/co2 ratio for lfe fires in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had our gas Baxi Combi inspected and serviced today, as it has been every year. Gas safety cert issued and says all okay, but engineer gave what I...
hi, I am after some advice, I recently fitted a new gas valve to a vaillant ecotec earlier. the boiler was fitted in 2015 and has been serviced...
2K
Hi, I am going to a job tomorrow where the customar says they have a 1 inch square valve head (what i would call a fire hydrant valve, maybe...
Hi, Can I pick your brains? My boiler is often reluctant to start, sometimes it does, sometimes it seems that it will if the demand is from the...
1K
Unable to adjust co2 readings on a a vaillant ecotec boiler it’s an lpg model I’m currently getting 0.0004 ratio, can’t get a higher co2...
3K
Deleted member 120897
