Discuss Column radiator - how to tell top from bottom in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi everyone, I'm looking to fit a small Nordic 3 column radiator, but the red plastic bung that indicated the top has been removed along with all the others.
I can see straight through the opening on the top and bottom and the diverter is separate, not already installed.
In short, without fitting it, I can't see a difference between top and bottom. I don't know if the direction of the thread on the bushes could be an indicator? Two bushes are threaded anticlockwise and two clockwise.
Thanks.
  • Nordic-Column.pdf
Bottom you can’t see through eg Because it has the diverter in
If there’s no difference between front/back or top/bottom then just choose the best face to be front and the best edge to be top.
Before fitting make sure that the valves will screw in where you want them, in terms of thread direction.
Okay so it doesn't make a difference as long as I put the diverter in the right place? Thanks.
Thanks, yes I'd read this elsewhere but unfortunately the diverter is separate with instructions to fit during installation.
Ok doesn’t make a difference then
Reply to Column radiator - how to tell top from bottom in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, I had my new boiler and 13 radiators installed in July last year, but since installed all the radiators always top half hot and bottom...
2K
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
Hi all, Just had a column radiator fitted with an ENZO TRV valve (non bi-directional) on the flow inlet pipe. When heating is turned on, the...
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
Hello everyone, Baxi Ecoblue System boiler which was recently serviced just before Christmas. There has since been a constant but slow drip...
