Discuss Combined direct vented hot water cylinder in the USA area at PlumbersForums.net
Hi, I have a combined direct vented hot water cylinder installed in my flat and it works on economy 7. Just recently I have noticed that when I open a hot tap the water didn't come out warm and also after about 2 minutes the cylinder or pipework to it started juddering. Just in case the heating controller was having an effect I turned off the controller waited until I could hear no more water filling the tank then turned on a hot tap. After 2 or 3 minutes it started making a noise so it appears not to be heat related. Can you help please.
Read more: Combined direct vented hot water cylinder - https://www.diynot.com/diy/threads/combined-direct-vented-hot-water-cylinder.547980/#ixzz6Qe9ONdFX
I've turned the heating controller off because I wanted to make sure that it had nothing to do with over heated water. So with it off and a hot tap open it still rumbles after a few minutes.
Does the rumble sound like it's coming from the cylinder? A bit like a ships horn? If so, new washer to float valve or new valve altogether.
Reply to Combined direct vented hot water cylinder in the USA area at PlumbersForums.net
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app...
