Discuss Comi boiler flow rates..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gary50
I have basically always been under the impression that if a boiler was specced wrong the hot water would run cold. I.e if you have 20lpm with a boiler that delivers 12lpm then you would still get 20lpm coming out the hot tap but it would only run warm as the boiler cannot handle the flow of water passing through the heat exchanger.
I have recently been told by Vallaint that the boilers have flow restrictors which will actually only limit the flow of water to the manufactures flow rates. So a 12lpm boiler will only ever allow 12lpm to exit the hot tap due to the restrictor.
i aslo phoned Worcester and they were a bit vague. They actually didn't know the answer and said although a flow restrictor was fitted it wasn't actually accurate.
Im pretty sure I've seen boilers with low flow rates fitted to cold water mains more powerful than the boiler flow rate and they still allow the maximum amount of water to pass.
So my question is who is right? this is very basic plumbing stuff but know of the manufactures appear to give a straight answer! Its almost like know one knows for sure!
Flow restrictions fitted. Installed a 24 pro Vaillant the other weak, cold flow rate was 22 l/pm but hot output when I commissioned was 9 l/pm.
Definitely restrictors fitted
Reply to Comi boiler flow rates..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
Hello, First post, be gentle! Anyway, here's my issue. I have a Roca The Gap D-Trit close-couple toilet with integrated macerator in my secondary...
Hi, can anyone tell me which pipes are flow and return please. I removed old leaking 2008 C26 firebird oil boiler in June . We have now...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my...
