Discuss Commissioning some elses' install in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bassmonster
I was just reading through this months "gas engineer" publication and came across the following:
When I sat my ACS exams not to long ago, one of the option was to Riddor the boiler if the install was carried out by someone who's unqualified which i thought was the correct answer at first.
However, it turns out that an engineer can comission the boiler.
what's the legal ins and outs...?
Don't know about putting a riddor on it unless you have seen the install, anyone who works on gas must be registered , you can if your silly enough commission and put your name on the paper work, I've never done it but there are people that will, is it the risk you are prepared take, This thing with Firemen doing work on the side has been going on for years, If you did all the work finding out who he is, and reported it to GS I doubt whether anything would be done about it
The legal standpoint is
knowingly.
If you knowingly by pre arrangement do the commissioning - you are also breaking the law.
If you turn up and find a system installed and it transpires it was done illegally. You can commission legally it and take full responsibility for the full monty - be it on your shoulders.
There thinking is they cant condone it and rightly so obviously.
But theyd rather have safe systems ultimately - than leave them in and refuse to allow
knowingly.
That is not what I got off gas safe.
They said I could commission the boiler. I would have to take responsibility for everything including the whole gas run flue etc.
they then said that in order to commission the boiler you have to check the seals, route, termination of the flue. Check the gas pipe in it's entire length as you don't know what they have touched. The wiring. The fixings and so on.
That is what ive just said.
Go to specs avers.
"You take responsibility for the full monty"
GRRRRRR really irritates me this. I used to work for a mate who would regularly get requests for commission only work, he had an apprentice at BG who would occasionally fit a system for the extra dosh and ask my mate to commission and register. His work was immaculate, his pipe bending second to none and his installs always spot on to the regs. My pal would do it for him as it was probably once every twelve months.
We also had referrals to commission from a local Gas Reg'd fitter, who would fit boilers then tell the customer to ring us to get it commissioned and registered. These installs were shocking, rubbish work, undersized pipe, flues stuck out 600mm from the wall, condense pipe cut at the other side of the wall and finished with a 22mm elbow draining down the wall. I rang Corgi once to double check the guy was registered and he was, they took no action !!!
I NEVER commission anyone else's work, been asked, but the ÂŁ1000 price puts people off !!!
I more often than not find its only the GSR engineers who actually care about whats going on .
I come across more and more builders that vary out gas work illegally, many a home owner carry out diy gas works .
We all know of guys that who work on gas through the week and on weekends do cash in handers.
Nothing happens not a jot .
Lost count the amount of uncommisioned boilers i come across nowadays.
On my gsr inspection in the summer the inspector said he will email the house we worked on direct about their gas faults we found.
The response from the home owner ' i never read his email just deleted it'
kinda says it all
an what an interesting read it is, i carry a copy in the van to show customers who want it doing, thus far none have!!!!
Had my gas safe probation lifted commissioning someone else's work. Worked for same company though. I pointed out loads of faults as did he and he sent an e-mail to company with a time limit to put things right.
That was my own personal registration, already had companies.
Reply to Commissioning some elses' install in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Not sure what my options are here. Basically a friend of mine recommended his father in law to do our plumbing/gas work for our renovation. First...
2K
Just browsing the threads and this one here // www .plumbersforums. net /threads /bldg-regs-compliance-interlock.103043/ caught my eye. 1. If a...
1K
Hi gents and ladies, Making the probable mistake of buying a house at present : bit of a fixer with a shoddy but recent boiler installation...
1K
I need some advice please. My Baxi boiler went recently faulty. A Baxi engineer came and fixed it in 10 minutes, he said that the ignition lead...
Had our gas Baxi Combi inspected and serviced today, as it has been every year. Gas safety cert issued and says all okay, but engineer gave what I...
