Discuss Condensation or leak in the USA area at PlumbersForums.net
Hi wondering if anyone could tell me if this is a normal pool of water from condensation coming from pipes. Or does it look more like a leak? Am I best cleaning it all up then trying to identify any small leaks? Thanks
Best replace them all
Reply to Condensation or leak in the USA area at PlumbersForums.net
I had a potential leak in the island kitchen drain, but it's no longer an issue after using an auger through the clean-out pipe. The water seemed...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
I have a leak from my shower, it's coming down into my kitchen. I've had the sealant, waste pipe and tray all checked. I've also had the shower...
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and...
Hi, I have a PRV located in a heated plant room that is between a pair of stop cocks. It was installed to keep pressure under 3 Bar a couple of...
