Discuss Confused about BSP thread size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pophops
Hi. I'm a new member so please be gentle with me!
I have a narrowboat and have been experiencing some problems with the exhaust leaking fumes.
I have fitted a new flexible coupling because the old bellows had split but now find that the silencer has rusted through and needs replacing.
I need to identify the correct thread so I can order the right silencer. I've undone the unions at each end but it's difficult to measure exactly the diameter of the threads in the confines of the engine hole and the silencer bracket is rusted solid so I'll need to do some more work before I can remove it..
The thread diameter on each end of the silencer appears to be around 2 1/4" (57mm) - difficult to be precise. The confusion arises because the nuts on both unions are stamped 1 1/4" on one of the flats and incidentally are stamped 'GC' on another. the nuts measure approx. 2 5/8" across the flats.
Could anyone identify for me what size of fittings these are?
Thanks for any replies.
Welcome along mate, you only need to post once as the moderators may see this as spam
The threads would be 2" ;
[DLMURL]http://www.floconfilters.com/images/bsp_new.jpg[/DLMURL]
GC may be Gas Council possibly a gas approved fitting.
1 1/4" doesn't make sense
How old is the boat?
If your narrowboat is as old as the one my sisters lives on then it could be any thread, reckon over the years we`ve found every imperial and metric threads known to man.
Do Halfords still sell those dunk in water and wrap around exhaust repair kits?
Reply to Confused about BSP thread size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
  • Sticky
We have 2 brand new cordless, battery powered press tools in stock, and flying off the shelves. Our TekTools TZ1930 & TZ1550 are packed with...
