Discuss Connector for combined bath overflow and supply in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I need advice on a water inlet pipe for a combined bath overflow and supply. I have uploaded photos. On one side is the attachment i need. In the attached pics one side of the fitting has the connector I need. It's missing from other side. Also how do you remove the fitting on left side? Looks like a radiator tail spanner
Silly me. Turns out hot and cold inputs are linked via a tee piece and then single mixed input enters the fitting on the right.
Forgettaboudit
Yes it’s fed by a blended supply.
But you should be able to swap it to the left side if you want to, just choose the side which will be most accessible in the future once the bath is in place.
Reply to Connector for combined bath overflow and supply in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
