Discuss Constant dripping from outside pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. Anyone know why I have constant dripping from the outside pipe. Been like this for a while now.
It’s like a curve shape.
Combo boiler is in the loft.
Do you know what the pressure is
Also any pics of the boiler from inside?
Would say you need a gas safe engy to sort the problem out
You need a Gsi to repair this paul, the expansion vessel has failed dont go pulling it apart nothing you can do bud . cheers kop
My opinion for what its worth you have to give the op something or we come across as arrogant and unhelpful, ruels still apply though, boilers with a casing that needs to be fitted and are part of the combustion, our posters may not be aware of this so thats why we treat them all the same and advise not to remove the casing and contact a GSI . Cheers kop
Technically there should be an inside case also on that boiler if I remember correctly. However the PRV is a safety device and should not be messed with by somebody not qualified to do so. I have no idea why people come on here and ask for professional advise and then when it’s not what they expect they ignore all responses as if they hadn’t asked in the first place. This website should have a function to instantly delete posts from people with no common sense, not just lock the posts.
Edit due to spelling mistake
Reply to Constant dripping from outside pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
