Discuss cool rad in the USA area at PlumbersForums.net
hi all
i have a prob with one of my rads I have 11 rads in the house one does not get hot changed the rad for a new one with new fittings still the same prob the pipework looks about 6mm thinking may be blocked with sludge is it worth it to change to maybe 10mm pipe to see if that solves the prob thanks
Probably wasn't necessary to change the radiator. Still, what's done is done.
Try running the system with all the other radiators turned off and turn the pump up if you can. Does that force water through the cool rad? If so, it's probably a balancing issue, or you've just cleared an airlock. Try turning the other radiators back on and see what happens.
Are you getting any flow at all into the new radiator? If not, try removing it and opening one valve at a time into a bucket. That will identify a possible blockage.
Reply to cool rad in the USA area at PlumbersForums.net
Sorry I have sort of asked this before, tried professionals but not great 1st experience hence DIY attempt attempt again. 2 completely cold...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
Hi, I have an 20yrs heat only potterton 50e boiler with 196x old house - suspended floor - designer radiators, open vent system and hot water...
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
